I use pages (4 columns in VC, only links, no picts, no special styles, no sidebar…) as Mega Menus. This works perfectly with all types of content (pages, post, categories) but not, if the pages are automatically generated by bbpress. In this cace I see in the menu instead the links the code like [vc_row][vc_column width="1/4"][vc_raw_html]JTNDZGl2JTIwY2xhc3MlM0QlMjJodGgtbWV ...
I didn’t modify the CSS-styles of bbpress or newsmag.
What can be the problem, what can I do?
Please help.
Ralf
We had a similar report when using MegaMenu from Pages feature and we are still working on finding a solution for this. It seems that the VC plugin somehow isn’t loaded on bbpress forum templates. The sidebars widgets work fine however the menu shortcodes aren’t interpreted by the VC plugin.
We will try to find a solution as soon as possible for this and include the fix in the next theme update.
Sorry for the inconvenience!
