megamenu offset on "scroll down" menu on some posts
hi,
just discovered something strange
on this post for exemple, when you scroll down and get the “pull down” menu, mega menu works just fine
https://www.welovetennis.fr/atp/atp-moselle-open/boutter-un-vrai-bon-cru
but on this one it gets an offset that makes it almost unusable
https://www.welovetennis.fr/laver-cup/la-laver-cup-resumee-en-1-cliche-et-quelques-stats
I suspect that it’s linked with the fact that the post has a tweet content… but not easy to debug
is there a fix ?
thanks
update
In composer no problem
https://pasteboard.co/IyGaX0R.png
On front site it bugs
https://pasteboard.co/IyGbxog.png
But changing browser window width seems to fix the issue!
https://pasteboard.co/IyGdeFc.png
OK so here comes a quick fix that seems to work
/* fix megamenu offset when post has a tweet */
(function($){
$(window).load(function() {
$(this).trigger(‘resize’)
})(jQuery)
  • This topic was modified 6 years by cantoute.
Viewing 1 post (of 1 total)
