MegaMenu Problem
How can i create a menu like the one on one of your demos with the menu on the side. Here is a snapshot
Screenshot
I only have one section that i need to add to it. I just need the menu to be on the left side. I read through all of the tutorial still not clear as to getting the menus like the on in the screenshot.
The menus are the ones is on the left side : all, business, health fitness etc..
The menu on the left is the sub-categories of the category selected for the megamenu. To add the left menu, add sub-categories to the category you are using for the megamenu.
do you mean sub item?.
Its a completely different page. When i move it right under it says sub item.
how do i go about adding sub category. I would appreciate a screenshot of how u added a sub category.
Hi Themuslc
My Apologies, I thought you were using the Category Function in posts to generate the MegaMenu. I haven’t tied this way, but I imagine if you are using pages, you would need to make the left menu pages have a parent of the top menu. So If you Top Menu was Holiday Destinations and yo wanted Menus on the left of Bali, Japan, Singapore, etc. Then you would make Bali, Japan, Singapore pages have a parent of Holiday Destinations. To do this is on the right hand sidebar when you are editing the page (change the circled “Parent” drop down to the top level menu):
Capture
  • This reply was modified 10 years by PWS.
The menu you see on our demo is a mega menu option. It is created like this: https://forum.tagdiv.com/mega-menu/
You can have a custom menu as well if you create a page menu. That way any content you create on a page will show up inside the mega menu:https://forum.tagdiv.com/page-menu/
