Megamenu problems with Chrome
Hi.
Sub menus are not loading if using chrome. Ajax returns a 302 error.
Any ideas?
This might be caused by a plugin, try to deactivate all your plugins except the ones provided with the theme and clear any caching installed. Then check to see if the menu is working properly.
Or check any customization you might have made to the theme files directly, or through a child theme.
