I have a few problems with the menu:
1. I have the boxed layout, but there are white lines extending from the menu both sides over the bg.
2. The menu items are centered. I have no idea how this happened, but ever since I installed the theme, the items were centered. I would like to have these left aligned.
3. The line underneath the menu items when hovering over an item, is not appearing.
Screenshot of problems: http://prntscr.com/4opmo4
My website: http://www.nonstopdestination.com
I would like to have the menu look like this demo page, boxed, left aligned and line underneath items: http://themeforest.net/item/newspaper/full_screen_preview/5489609
Another problem I’m having is the parallax is not working on the big feature images. Also on the pages where I have the big feature image, there is a space between the menu and the image.
Example page: http://www.nonstopdestination.com/amsterdam-photo-essay/
Any help is greatly appreciated.
The lines appear because you are using the “Blog style” header style, you can change it from theme panel > header > header style http://screencast.com/t/6nMiErBKpArI
Use another header style, the menu items are centered all the same reason the demo uses header style 1, you will get the the line underneath the menu items when hovering also if you change the header style.
I have checked your site and found this errors in the console, this is why the parallax images don’t work: http://screencast.com/t/W1xEwv93I
Please make sure you deactivate all plugins and check Agana also empty cache files if you use any. Regarding the space between menu and feature image that will disappear if you change the header style.
Please let me know what you find.
Hi Lucian,
Thank you for your reply.
I changed the header style and it’s exactly how I want it, thanks!
For the parallax problem, it looks like it’s the Tekanewa visual composer extension that is breaking the parallax. http://tekanewascripts.info/composer/ which I’m using on these pages.
As soon as I put one component of this extension on a page with parallax, it breaks.
Not sure if this is anything you can help with?
Glad to read that you have managed to get it how you like.
We haven’t made any tests with any VC extensions so I can’t tell you what issue you might experiencing.
Sorry about this. You could try to hire a freelancer from sites like: http://studio.envato.com/ to get this dose for you.
