The menu is taking a moment to load. I can’t seem to find the setting
Our objective is for Navigation Text to be there when the site loads.
Image Link: http://prntscr.com/qn7br5
Video: https://screencast-o-matic.com/watch/cYVIqgvgPz
Longer Video: https://screencast-o-matic.com/watch/cYVIqJvg9Z
Thank you
Is look that the menu have set first the color black and only after that is apply the color white, what you can do is to apply a stronger custom css and set it in theme panel> analytics like this -> https://i.imgur.com/PSlbmgV.png
<style>
.tdb-menu > li > a{
color: #fff!important;
</style>
Hope this will help you!
https://screencast-o-matic.com/watch/cYVoYTv57d
Thank very much (again) for your support and great template.
> I truly mean that …
1) I appreciate your really specific reply (and)
2) I added the code as suggested ( but)
Personal Note:
–> After watching your promotional videos <–
I was very much under the impression that this menu was configurable.. I did absolutely nothing to it to have it load slowly or have Black (before) white?
1) Is there any animation setting for this?
2) I HAVE NEVER SEEN AN ANIMATED MENUE?
My happy solution would be…
> I JUST WANT A BLACK MENU BAR WITH WHITE LETTERS.
That code should solved the problem, but is look that this is still not working correctly -> https://i.imgur.com/zb6U8am.png also this is the code that set the animation on menu -> https://i.imgur.com/5xrkYnV.png -> https://i.imgur.com/j1IY0gs.png
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
