I’m using the tagdiv composer to edit my header template.
I’d like to change the background color and opacity of the header zone, and the sticky header zone.
Please see this capture : https://ibb.co/k6cyHGN
I think i’m doing this propoerly however it doesn’t work.
Could you please help me ?
Regards,
Nicolas
Please make sure that you click on zone, and in order to use opacity you need to have set and background image -> https://www.screencast.com/t/Ir9R20CKZWG
If I understand correctly you want to set the revolution slider under menu in header, if is so then you can try to set the revolution slider link this -> https://www.screencast.com/t/6Q9pQgY0R
