Menu color problem & Block header difference
First of all thanks for creating such kind of a great theme. It’s really amazing. I have encountered two problems while customizing the theme:
1. I have added categories and pages to my main menu and customized the menu colors. Menu colors are being shown in pages as I have customized (Red) but whenever I go to any category page main menu colors are getting back to their default colors (Blue in this case). I tried to fix it from Tagdiv Composer on the Category template, but everything looks fine there. Here are the images regarding the problem:
https://drive.google.com/file/d/1CZHdEQOZXXGmFv456HNX1xzddSMjSRKW/view?usp=sharing
https://drive.google.com/file/d/1244r4vXuxGTYgRpOu5gVlW3Og89hn5w9/view?usp=sharing
2. I use Flex Block 3 on the Home page and headers have been set to Global Header in Tagdiv Composer. But sometimes headers on different blocks (all are Flex Block 3) are shown in a different ways despite the settings are the same. I changed them to Block Header 1 – Default, but it doesn’t help. Here are the images regarding the problem:
https://drive.google.com/file/d/1urGJ4xZFGdB62i2RO4C0d6-fhqwr4C8H/view?usp=sharing
https://drive.google.com/file/d/1gVJlTaOlhHp7xf1tNstmLZgTKVzeNJs7/view?usp=sharing
Could you please help me with these?
Thanks in advance!
1. If you have installed the last theme version10.4, please do these steps.
1. disable all tagDiv plugins
2. uninstall all tagDiv plugins
4. re-install all tagDiv plugins again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate all tagDiv plugins
Please let me know the results.
2. Please try to do a test using only tagDiv plugins, and see if the style will change.
Also, please send the link to your website.
Hello
I did all steps and 1st problem solved. Thank you very much!
But 2nd problem regarding the block headers still exists. I tested tagDiv plugins, but it didn’t affect the problem.
Here is the link to my website which is under construction:
http://mdq.txi.mybluehost.me/
Related to the appearance of the block title it can change for each one, even if it is the same block, for example for this block you set a filter https://www.screencast.com/t/dPZsHCJ8Ju -> https://www.screencast.com/t/sAz2GBDIzo, so if you want to have the title of blocks be the same, then you need to set the ajax categories dropdown to “No dropdown ajax filter” => https://www.screencast.com/t/Ks4o8HOs5cv
You can find more tutorials on our channel on youtube =>https://www.youtube.com/user/tagdiv which can help you to redesign.
Hope this helps you!
ok Thanks a lot
