The mobile menu has a specific background(black). Unfortunately there is no option in panel to change it, but you can use this custom css in Theme Panel > Custom Css, just add your color(also for icons if you want): http://screencast.com/t/lMy1un0oBNu
@media (max-width: 767px) {
.td-header-wrap .td-header-menu-wrap-full, .td-header-wrap .td-header-menu-wrap, .td-header-wrap .td-header-main-menu {
background-color: #fff !important;
#td-top-mobile-toggle i, .header-search-wrap #td-header-search-button .td-icon-search {
color: #222 !important;
Hope this helps!
@deelauaki This can be caused by Speed Booster plugin(if you use it) which move the css and js at the bottom of the page structure so that the page will load faster, this is why the theme default color appears first then changes, because of the cascading property of css. A solution is to change the color directly into css stylesheet file – http://screencast.com/t/hbjKLA3pjKA – http://screencast.com/t/YLOcOHterf
Please make sure you have permission to upload folder, you may need to ask your host for assistance.
