Menu Icon Problem
Hello, while editing, icons appear in the menu. However, after saving, the icons do not appear on the live site. Why could it be?
https://prnt.sc/yHT4DUPYHGIV
Live site
Editpage
https://prnt.sc/qkLVvpgJ6Soj
Hello @anubis60 !
Delete all the cache and try again. They should display well if there is not a plugin conflict.
Hi, I have cleaned it many times but the situation is the same.
I haven’t installed a plugin yet.
Hello @anubis60 !
Disable the lazy load animation from here: https://www.screencast.com/t/O5pfqQdb and see the results.
If the problem is still there, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will take a look and try to help you asap.
