My search button dropped to a 2nd line on the menu. I shortened ADVERTISE to ADS thinking the width was an issue. Not sure why this is doing this.
Thank
@pmerlihan Seems the issue is solved at the moment
– https://www.screencast.com/t/SOHNOn26xhm4
If you have similar issues please try to got in the theme panel and click on the save settings button. Then clear all caching and check the results. Let is know the results.
Nope. I reverted my site back to 8.2. I had other issues on the site as well. The menu is messed up. I was playing in the theme dashboard and wanted to see what the social icons looked like in the menu — they placed under the menu with search. I toggled that feature off but it refused to remove it. I cleared cache and nothing worked. I did a back up of my site just before adding the update.
Problem not fixed is the short answer.
@pmerlihan I believe at the time of inspecting the website I checked, the latest version of the theme was installed, but I could be wrong.
However we will make further investigations in this matter and fix the issues found, in a theme update. This will happen as soon as possible.
In almost all cases the issue with the search was fixed by the method mentioned above, it is very important to clear all caches after the update. There will be a theme update coming shortly, containing various fixes. Please make the update and check if the issue is still present.
If it is, send us an email at contact@tagdiv.com and provide admin login information so we can investigate further.
