The first time people visit my site often the main menu will not load, instead the entire bar appears black.
If they click through to another page or article on the site the problem no longer occurs.
Can you please see what is causing the issue?
Site:
http://smallcaps.com.au
The menu I am referring to that doesn’t load is the one with:
“News, Top Stocks, Sectors, etc..”
Hello WakeUpCallProject,
I have inspected your website and I did not saw any problems with your menu. It seems to work as properly. If the problem will re-appears, please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins.
