menu problem
the problem is went i login to WP .. the menu are the likes of what I have setting, but when I get log out WP .. the menu will be incorrect. . Can u help me 🙁
1. View menu went i login WP – http://umnosubang.com.my/wp-content/uploads/2015/12/22.jpg
2. View menu went i log out Wp – http://umnosubang.com.my/wp-content/uploads/2015/12/21-1.jpg
I have checked your website and the menu that appeaser is the logged in version you pointed out: http://screencast.com/t/VuUgaobw2H
there is only one version of the menu in our theme that does not check if you are logged in or not. Please try it without any plugins and clear cache to rule out a plugin conflict. You also have errors in your console so a conflict could be the case.
Let us know how it goes.
