Menu problem
Hallo, i have a very big problem with mobile menu.
My website is topnews(dot)gr
I disabled all plugins, clean cache
Remove cloudflare clean cache
But i still have the problem (visit page with mobile to see problem)
Try menu at homepage and in articles
I have checked your mobile menu on homepage – http://screencast.com/t/zd9ZacyJJi but did not found any issue but on article page it seems that the menu button link is affected – http://screencast.com/t/72VnzE4Mt I suspect that it comes from a script that you use or it is added by a plugin- http://screencast.com/t/dNrLlglwyQP Please disable all the plugins except Visual Composer, clear all the cache, purge your files and remove any custom modifications that could cause this and see if you still have this issue. I could not found any issue on mobile menu, also you can try to do a clean theme install on a subdomain or local and test it only whit the plugins provided with the theme and without any custom modifications and check it.
The problem cretaed by ezoic.com code at header
<script type=”text/javascript”>var ezouid = “248097265”;</script><script type=”text/javascript”>var ezouid = “248097265”;</script><link rel=’canonical’ href=’http://www.topnews.gr/wp-admin/admin-ajax.php&#8217; /><base href=”http://www.topnews.gr/wp-admin/admin-ajax.php”&gt;
But i need this code.
If I remember well I have replied also on dashboard regarding this, unfortunately this code cause issues to the theme so please review your code, make sure it is correct and contact the person who provided and as him about this as it affect the theme’s menu and search buttons on mobile and I cannot provide a solution for it.
