Menu problem – page not linking
I’m trying to customise the Newspaper template. I have a published page that I’m tying to link to the main menu, but I can’t get it to work. When I click on the relevant part of the menu, it doesn’t link to the page. I can see the page and its permalink on the dashboard, but can’t figure out what I’m not doing in the ‘Menu’ section of the dashboard, to get the page to link to the menu.
Hello dear,
Please ensure that you have right added your page to the main menu, according to our documentation here -> https://forum.tagdiv.com/main-menu/ Make sure that you are using the latest version of theme and also, ensure that you are using the latest version of required plugins which come bundled with the theme packet and rule out any conflicting plugins. If you are using some untested plugins, try to disable all of these. Clear all your caches and check the results. Re-save your permalinks and check the results.
