Menu problem
I have problem with menu.
The problem is that the text in the menu compacted, and not in a single line.
Been using W3 Total Cache, I attempted without W3, but the situation is the same.
Any help?
[code]Site is cakovec.hr/web[/code]
  • This topic was modified 12 years by infenso.
That is a bug when resize the browser at mobile version and refresh the page, then go back to full screen, the java-script don’t resize the menu again, only on refresh.
We have update theme to 3.5, but there is still that bug with menu.
Any news when we can expect bug fix?
Thx
You have a incompatibility there. The menu should work fine. Please disable all plugins or one by one and see if works.
Thanks and sorry for long delay!
I found it. Only plugin that we didn’t tested/disables is NextGEN gallery plugin.
Now it’s everything ok.
Thx
