Could you please help me with the following:
(the website is http://www.ministryofrun.com )
1) Desktop view, suddenly there are some styling issues as below.
The strange thing is that it is displayed as it should be on my local dev.
2) On mobile view, the menu is not working at all. Clicking on it does nothing.
3) Searchbar styling issue:
thanks
Unfortunately minifying css and js could cause issues which why we don’t recommend it. You could try if you like to manually minify themes’s css and/or js and avoid this conflict by excluding the js or css causing issues.
The issue you have with the search form is because of some additional styling you have added, you can use this custom css to fix it: http://screencast.com/t/ND6LBfItg9yK
.header-search-wrap .dropdown-menu #td-header-search {
height: 23px !important;
.header-search-wrap .dropdown-menu .btn {
height: 33px;
top: 19px;
border-radius: 6px;
