Another minor issue:
Menu overlaps with the shopping cart – just need to change the default z-index.
(found it on my way to try to eliminate the huge Layout shift issues in the menu/nav bar see here
https://forum.tagdiv.com/topic/cls-default-theme-settings/ )
The z-index from the shopping cart can be changed using a custom css like this one
body .td_woo_menu_login .tdw-wml-menu, body .td_woo_menu_cart .tdw-wmc-widget {
z-index: 1;
Set the code in the theme panel > custom code > custom css.
Also, if you want, you can adjust the z-index number.
