Menu speed
What can we do to speed up menu load. There is a delay when you try and open menu first time and then it’s fast. Not sure why. I tested on your demo too and it is difficult for our readers to navigate especially they are on a very slow connection.
We are still using the mobile theme and it’s still making us wait a few seconds before it loads first time. Same thing happens when you navigate to other pages
Unfortunately the mobile menu does indeed take a bit of time on it’s first load as the graphics have to be loaded first for it. Try not to use a mobile background image. Try to add simple color to it as colors load faster than images. There is little to be done about this though. The mobile menu loads faster on some browsers like chrome and slower on others such as firefox or ie 10-
Hmm
I’m not using any images just text. How come other themes don’t have this issue… what’s the little that can be done as it’s just text… apart from removing background image
Other theme s do not use our own mobile menu. It is not the same element that runs better on a theme and on another one not. It is our own custom made menu. Please provide a link to your site so I can inspect it and see how the menu loads.
I understand #
What I am saying is that how come all themes I have use … which is a lt for different sites, none have issue with delay in menu loading? must be something you need to address
Please provide a link ti your site so i can inspect the menu. We are not seeing any major delays on our end. Please check this menu: http://demo.tagdiv.com/newspaper/ does it load as slow as yours?
Just sent it
I have started using keycdn imagify doing so much stuff I never even did for the other themes we use and can’t break through the speed . Our old ugly theme was much faster without any of these and even more plugins do you can understand my frustration.
Sent it by email
preloading the critical CSS in your ‘header.php’ file is fastest way to load menus.
