Menus OVER not work in home page
I’m having an issue with the Newspaper plugin menu. I have some custom links and categories with sub-items under each one. When I’m on the homepage, hovering over a menu item does not display the sub-items. However, if I go to any post or internal page, the hover works perfectly and the submenus appear as expected.
I’m not sure why the menu seems blocked from showing sub-items on the homepage. Could anyone help me understand what might be causing this and how to fix it?
I saw similar cases when the situation was caused by an extra plugin, usually a cache plugin. Please do a test and see if this situation persists when you are logged in or only when you are not logged in. If it is working when you are logged in, then you need to check the settings from your cache plugin, especially for CSS and JS.
