Hi, i use review on posts and metadata td_review_key to show it on front page grid boxes. But on the page itself it shows 87.01% Percentage but on the boxes with the metadata used it gives the equal rate number from 4.35/5. How can i show same 87.01 on the grid box with metadata usage? Is the td_review_key wrong meta key for it? Thanks.
1 – https://drive.google.com/open?id=0B3a76_4Q44pFR0gzLVZ4MVppM0k
2 – https://drive.google.com/open?id=0B3a76_4Q44pFUWM1OFgzd2swcE0
You do not have to add anything on the homepage blocks for them to show the reviews. They do so by default and they pull the correct review: http://screencast.com/t/qwwlJpiwM – http://screencast.com/t/P4i0tw9iVhi
Unfortunately that is the only meta of the reviews, there is no other one. You can find all of the metas in this file: http://screencast.com/t/HPqNUov1v I’m not sure the theme reviews will work the way you want them to as we have not tried pulling the information into an external plugin. If you cannot manage to get it working, we suggest hiring a developer to help out as plugin implementation is not part of the theme support.
