Meta tags going to body
meta tags going into body tags but it should be within head tag. But when I am installing other theme the meta tags are showing within head tag.
What is the problem?
I have solved the problem but for what I was inspecting the main problem with my Opengraph overlay. It is not producing an image but working with other themes. Can you help me out why it is happening?
In other theme the link (https://newspost24.com/wp-content/plugins/detailsinfo-meta/fbimg.php?img=https%253A%252F%252Fnewspost24.com%252Fwp-content%252Fuploads%252F2019%252F12%252FNational-Memorium.jpg&post_id=26096)
was generating this image (https://www.screencast.com/t/jP0TMHcPw2 )
But whenever active newspaper theme it’s showing blank (https://www.screencast.com/t/Z2txxvdvXD).
Thanks in Advance.
Please make sure that you have the latest version of Newspaper them v10.2
Unfortunately we did not tested the Opengraph plugin and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
