Method “Load More” & “Infinite Load” does not work on all computers. On one computer when you open the site works, on the computer of another person does not work. What could be the reason?
For example page http://zvuk-m.com/fedos.html
There are two such blocks, the “Load More” works on my computer and does not work on a friend’s computer. Operating systems and browsers are the same.
The problematic computers constantly spin GIF Download and nothing happens.
At them on your demo page (https://demo.tagdiv.com/newspaper/block-1/) all works perfectly!
I can not understand anything (((
It seems that the ajax request is being blocked – https://www.screencast.com/t/W63FmaM962Ky Please try to deactivate all your plugins except Visual composer to rule out any plugin interference, clear the cache and check again. Also check any modifications you might have made to the theme files, and deactivate the child theme if you use one.
