Hey guys, I´m still having problem using W3 Total Cache Plugin.
When I enable Minify JS, my background and “load more” button stop working.
I´m having this problem since older versions.
My site is too slow, I changed from Godaddy to Hostgator and It´s still the same.
I´m getting 62/83 points in Pagespeed, so I really need to do everything possible to make it better, including minify JS.
Please, what should I do?
website: http://emagrecersemdieta.com.br
thanks again!
You can minify the HTML with W3 Total Cache and for js make it manually using this tool http://closure-compiler.appspot.com/home
Another things, optimize your images add this filter in function.php
add_filter( 'jpeg_quality', create_function( '', 'return 60;' ) );
Also you can read more tips here: https://forum.tagdiv.com/topic/pagespeed/ or search on our forum.
