Missing Comment Box on Certain Articles While Others Are Fine…
Our comment box has disappeared on certain posts as seen:
here: https://prettyprimp.com/2017/08/27/best-cheap-eyeshadow-palettes/
and
https://prettyprimp.com/2017/09/11/how-to-fix-damaged-hair/
Yet appears on other posts such as…
https://prettyprimp.com/2017/09/26/sneaky-things-that-cause-acne/
and
https://prettyprimp.com/2017/10/10/fall-hair-trends/
I believe all settings are correct to allow comments…
Any help resolving this issue would be greatly appreciated.
Best,
Alex
From the posts that have the comments section I can see you are not using the default commenting section
– https://www.screencast.com/t/OYziKrq7JV
Please check the comment plugin settings, if you are using a plugin. It could be a setting if it displays on some posts, but not all.
The default comments will display if enabled in WordPress, also in these locations in the theme and individual post settings
– https://www.screencast.com/t/GtjTuH4TdP
– https://www.screencast.com/t/2swiKsFxlNZ
