Missing Comment Box
Help!!!
Why there are no comment box on my wordpress posts?
How do I solve this?
I have tried enabled the comments on Newspaper Panel & WordPress Settings…but still doesn’t show up!!
Here is my post – Picture
Did you enable comments on tha actual post using the ckeckbox?!!
Yes I did – Here (Picture)
But it still doesn’t show up. How come?
Hello Thomascth,
Please clear all the caches and check the results. If these settings are enabled, at the bottom of your posts you will have to bring some comments for that posts. Otherwise, these will be hidden. Also, check the general settings of WordPress from here -> https://www.screencast.com/t/lxLYu0RkDLUN to have enabled the Discursion settings.
Hope this helps!
