Missing Widgets From Article Posts/Footer
Hi there,
I just recently installed the Newsmag template.
I’m currently facing two dilemmas.
PROBLEM #1: The right side of my posts look so empty right now. (See example: https://www.berkeleyobserver.com/2025/05/02/berkeley-county-enters-drought-as-dry-spell-worsens/) How do I add the widgets that are on my homepage to the posts of my articles?
I attempted to add the widgets to my posts by going to Appearance –> Widgets; however, after uploading this Newsmag, I’m missing A LOT of blocks.
For the homepage, I used the TagDiv Composer to drop/drag the widgets. I don’t appear to have that option with article posts.
PROBLEM #2: Because I appear to be missing a lot of blocks, I believe this is why I also cannot also edit the footer.
Any assistance with these two issues would be greatly appreciated. I have tried to YouTube the solution and Google it, but I’m striking out.
Thank you for your help with this!
Sincerely,
Nikki
I managed a workaround. I no longer need this answered. Thank you.
