Mixed Content – Errors (help)
※link
https://politicadeverdade.com/totosite
※error message :
1) The Mixed content tests failed. Please be sure that you can connect to your site over SSL and try again.
Error Returned: Navigation timeout of 30000 ms exceeded
2) DevTools failed to load source map: Could not load content for chrome-extension://eakacpaijcpapndcfffdgphdiccmpknp/scripts/content_page.map: System error: net::ERR_BLOCKED_BY_CLIENT
★There is a problem with that post. how can i solve it? help
error message
3) content_page.js:2506 Bartender API access denied.
1. This problem can be resolved by using an SSL plugin – https://wordpress.org/plugins/really-simple-ssl/
2. This situation is made by an extension that you have installed on your chrome if you check it in incognito the problem should no longer appear.
3. I believe that this problem is something similar to the one from here – https://wordpress.org/support/topic/bartender-api-access-denied-2/
Please tell me the optimal setting method that does not damage the current theme setting. What is the best thing to check?
Normally, most of the time it is enough to use the default settings without changing them, therefore, the settings that are now should be fine.
