Mixed Content Problem
I have SSL certificate which were showing https:// in my previous wordpress themes flawlessly. But now, many of our posts are showing content not secure (http) SSL problem. It is because of mixed content. HELP!
Are you sure the theme is not causing this issue? Any theme element loading over http can cause this.
Without extra plugins the only thing that can create this problem is a link set somewhere in the theme and this is set with http instead of new version https.
Ok. I have not added any links with HTTP. I always take care of these things. So that’s not the possibility of the issue.
Did you try the above suggestions?
Sometimes this can be resolve by only install a ssl plugin like Really Simple SSL plugin -> https://wordpress.org/plugins/really-simple-ssl/
Yes, but still sometimes this problem occurs. 🙁
As I can see, there are other problems that occur now -> https://i.imgur.com/cvRwPtX.png
Is possible that a problem to be cause by another one.
Oh! Now what is this new problem? How to solve it?
Is look that now you have only these errors, the rest of them seems to be resolved -> https://i.imgur.com/BltUZfx.png for this problem, please check this article about How to solve the ‘jQuery is not defined’ error?
Hope it will help you!
