When I run my website in mobile mode, it says no mobile content and when I run it as desktop and responsively change the display size, it gets disturbed. You can find the images in this link: Link
What can I do to reslove this issu? how can I edit the theme as mobile? And I want to use the same footer in mobile as in desktop.
This is the page: Link
thank you.
Seems you have the mobile theme plugin activated please deactivate it, clear all cache and check after the mobile version, if you don’t want to use the mobile theme plugin.
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
Hope this helps you!
