I created a mobile page and copied the content from desktop. It removed my header and when I go to edit it says that “this type header is not editable with tagdiv composer, please use a cloud template” however, no cloud templates are available in composer and it does not let me apply the one that I set as global. I have no ability to edit the header at all.
If you have created mobile templates, then you need to convert the header/footer -> https://www.screencast.com/t/HrjOBNayd please check this video https://www.youtube.com/watch?v=SpGkOnJeNZY to be able to edit them with tagDiv Composer.
