Mobile header not staying within container
I have updated to 7. I tried out the new mobile theme but reverted back to the original responsive theme.
However, when i scroll down on a mobile device the menu seems to break from the container.
Would you be able to assist me with this?
Please see http://www.londonnewsonline.co.uk.
I look forward to your reply
I have checked your site and apart from the fact that your visual composer plugin is not active, I could not find any errors. i have tested it on multiple devices but the mobile menu works fine. Maybe it was a caching issue and it since then got cleared.
Let us know if you still have trouble with this.
Than you!
Hi Bogdan,
I have just checked my site and it looks like the VC is active but giving me the update to v4.12 message. Sorry i meant the header. When i scroll down it extends.
Could the problem be with my current version of visual composer?
I have cleared all cache and browser data, but problem still persists.
Can you please post a screenshot of this issue as I have checked your site again and could not see any issues with the header. (you can ignore the update as you can only update visual composer from the theme package you download from envato. We have not yet released version 4.12 of VC but plan on doing so this week)
Hi Bogdan,
Please find below the screen shot.
http://pasteboard.co/7MfA4GQH3.png
On my mobile devices I cannot see the issue only on the browser emulator. Please try to disable all plugins except visual composer, clear cache and reset cdn files. Then test the menu again. if the problem is still there, please try to activate the main theme as you may have some code in the child theme that could affect the header.
Let us know how it goes.
Hi Bogdan,
Turns out i had the following script in the mobile portrait media query for another form on the site.
input[type=text] {width:200px;max-width:200%;}
All is fixed now and working.
Thanks for your help on this matter
Thank you
Glad you figured it out!
Have a nice day!
