Mobile Header w/ Ad Problem
The mobile header is displaying incorrectly when there is an ad in the header. Basically it shows the logo and then covers part of it with the add under it and then the menu. Any thoughts on fixing this?
Site in question:
http://www.android-advice.com
We are working to fix that … it’s a known issue for some time 😐
sorry for the delay and thanks for reporting this!
@mofiki thanks for helping other here on this forum!
No problem, I love the theme and want to be sure others are happy with it as well to ensure its continued success and support 🙂
@mofiki you are a great man! Thanks for all things you do.
Have a nice day!
Hi Marius,
I was about to post about this same issue with logo on mobile devices being covered when displaying a header ad at top.
Any thoughts as to when you guys may have a fix?
We working to fix that bug on mobile, is a little tricky.
Thanks for your message
I am having the same issue. Seems like it still isn’t fixed in the most recent update. Is there a way around this?
Will be fixed ASAP, please give us more time. We know about that bug.
Thanks for understanding!
