Mobile menu does not work
Our mobile menu has stopped working on mobile. It work fine when the browser window is shrunk, or when chrome is used to “emulate” a screen size, but it doesn’t work on an actual android phone (Nexus 5).
Url : http://denimology.com/
Any help would be appreciated.
I opened the debugger through chrome for the Nexus 5 and this is the error that is popping up:
Error when loading script
(The ver=x is due to the latest full update of Newspaper having it’s version number set to “x”. Even after applying the patch update which has the correct ver=3.4 I’m still getting the error)
  • This reply was modified 12 years by denimology. Reason: Clarification of "ver=x"
hi,
what plugings are you using?
if you use speedbooster plugin disable it.
if you use a caching plugin (like W3 Total Cache) disable the minify js option
you can also try disable all the plugins and try again, if this fixes the problem then one of those plugins is to blame
Thanks for you message.
Radu A.
