Mobile Menu element not displaying properly in Retro Blog Pro
Second Newspaper licence, first time issue with this element. I’ve added the mobile menu to a customised Retro Blog Pro template and, when clicked on, it is not displaying properly (in all viewports). See here:
https://ibb.co/VJR85Lh
and
https://ibb.co/5YMqgv8
Could you please help fix it?
Domain: https://ur-milano.it/
I can provide admin credentials if needed.
Edo
That’s weird! The issue could be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know about your results!
Hello Anamaria,
thank you for your reply. I’ve deactivated all plugins, one by one, to no avail. I’m not using a child theme or cache plugin. Would you be so kind to look further into it? Let me know if I need to assist in any way.
Many thanks,
Edo
Hi setteseitennis,
You are using the mobile menu on desktop, and that is way it looks like that. Also you do not have set for mobile menu a background color or image, please set it from here -> https://i.imgur.com/tEPHwKZ.png or here -> https://i.imgur.com/zlHokD1.png then it will look like this when you access the mobile menu https://i.imgur.com/kDgIpHa.png
Also if you want to set the mobile menu on desktop to take only a part of desktop screen, please check the suggestions from this topic https://forum.tagdiv.com/topic/php-version-7-4/
I hope this will help you!
Hi Calin,
thank you for your precious help. With the background color (second link) set, it works now. As for the mobile menu on desktop, that’s the only button available in the tag div composer for a hamburger menu, which I’ve seen on almost all the websites around.
Many thanks,
Edo
