Mobile Menu Issue: Please Read
My main mobile menu works for everything but the About and Disclosure, which are I tested as both pages and custom links. The footer mobile menu does not allow either to work, as well. However, “home” which is also a page, does work.
In both cases when I click on About, it brings up a page that says “about” and that’s it. It’s the same type of thing for disclosure, too.
These work on the desktop.
However, when I look at the posts section of the dashboard (while mobile editing – I don’t usually mobile edit but I’m trying to solve this frustrating issue) and I click on “preview” THE SAME EXACT ISSUE happens, where it will say either About or Disclosure, respectively.
Now, I’ve spent hours reading about this and I have tried deactivating plug-in and etc. Nothing to this point has worked.
Please advise.
If you use the mobile plugin, you have to create pages for the mobile theme to show since it will not show those on the desktop or those made with page builder. Just open both pages in the page editor and scroll to the very bottom and you will see a mobile editor where you can make the changes (either copy and paste the content in the page editor to mobile editor if it is HTML, or create the pages afresh in HTML if you built them with page builder). You can also disable the mobile plugin because the theme is responsive and your pages will show on mobile devices.
You are welcome.
