Mobile menu issue with categories and megamenu
Hi, (re: NewsMag theme)
If you setup your main menu structure with Custom Links and use the “make this a category mega menu” option, then a category that does not have any sub-categories is not selectable using the mobile menu. I thought you could have a category as a mega-menu that does not have any sub-categories? What is the workaround for this?
See: http://181.224.138.121/~signalko/ under IOS (Safari browser)
I’ve checked your site and noticed that don’t have any navigation links set on main category items, that’s why on mobile they don’t link anywhere. You have to set a navigation link for menu items displayed on mobile otherwise they will be inactive. You can use any category as mega menu item, it does not matter if have or not a subcategory.
Andrei,
Thanks a lot, I get it now but can’t seem to set a relative URL (it always appends an http?) I’m staging right now and not at my final domain name. Will WP change the URLs when I update my site domain name?
Word-press won’t change the links set for menu items, you will have to update them after you move to your final domain.
