I have two problems with my site:
1) The mobile menu / burger icon is not working. When I click on the menu on my iPhone the menu does not open. Same for the search icon.
2) I can no more change the DTP text color for main menu active & hover. Color does not change anymore.
I think I have booth problems since yesterday. They were not bevore, color and mobile menu has worked fine. The only thing I changed yesterday was that I created the hompeage with your page builder and that I have switched to sticky menu. And yes I know that it has sepaerate settings for sticky menu but this does nothing change.
What I have done:
Switched back to normal menu
Reinstalled the theme
deactivated all plugins
deactivated Cloudflare cache/minification
I have no caching plugin installed at the moment.
But nothing has worked.
Can you please help me with this? I can send you the URL in a private message…
Thanks,
Florian
This is most likely caused by a js error either from a script you added to the theme or coming from a plugin conflict. If you say nothing worked in your debugging of the issues, please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation so we can identify you.
Than you!
