Mobile Menu Problem
Hey my site is https://www.techlegends.in But i am getting double menu options while browsing through mobile. But the desktop version is fine.
The menu is showing those duplicated items because you have set them to use the mega menu which by default it displays the subcategories of a category and you’ve also set the subcategories as sub items which is not necessary when using mega menu so you can noticed that you gave the same issue as on mobiles on desktop also: http://screencast.com/t/ptRri7ezfT
You need to remove this ones: http://screencast.com/t/RPRkEEFlnkdD from appearance > menus panel leaving just the category set to use the mega menu: https://forum.tagdiv.com/how-to-use-the-megamenu/
  • This reply was modified 11 years by Lucian.
Thank you for checking that up. I meant the Menu is fine ( no problem with working ). But i see the menu under APPS – as Android Windows iOS two times. But you can see it in the desktop version once.
I have checked this issue with Micromax Unite 2, Galaxy S Duos and S Duos 2 which i have with me.
I have edited the reply above, just follow the mega menu documentation and you should figure this out: https://forum.tagdiv.com/how-to-use-the-megamenu/
