Hello, I have a problem with the Mobile Menu. When clicking on the menu and scroll down a bit, then broke the top of the site. Check this out using mobile phone.
site : http://2paclegacy.net/
My version is : V 6.6.4
Screenshots:
Broken mobile menu
Broken site after used mobile menu
Thanks for support.
This topic was modified 10 years by
calisangels. Reason: adding version
Hello calisangels,
I have checked your website and your console and saw that you have some js.errors, as you can see here -> http://screencast.com/t/ednRzRnEu0XJ This kind of errors could come from plugins in conflict. Please try to disable all the active plugins, except Visual Composer, clear all cache and install only the plugins that come bundled with our theme and rule out the interference between untested plugins and our theme. As you can see, we have a list of tested plugins with that the theme works perfectly -> http://screencast.com/t/0kBXe1my
Also, you can try to see the theme behavior using our demo preview on mobile and notice that issue does not come from the theme but only from the conflicting plugins. ->http://demo.tagdiv.com/newspaper/#
Thank you for the message!
Hello, thanks for response.
Currently, all plugins are disabled now, but the problem continue. Only WPBakery Visual Composer is active.
I will leave them disable until you check the site again
i test it. I have a problem only when i add element – all Big Gride and all Blocks. My problem is not plugins in conflict. I removed Big Gride now and work fine, but i want to have Big Gride or blocks on my top page
Can you help me?
calisangels.
Hello calisangels,
Please send us an email at contact@tagdiv.com with your credentials so we can further inspect the issue. Also, please provide the link of this topic so we know who you are and what the issue is.
