Mobile menu problem
hello! After installing mobile menu I realized, that certain menu categories wont show up on my mobile version.
For instance, those categories content missing only on mobile version: http://www.slavicsac.com/advertise/
http://www.slavicsac.com/contact/
http://www.slavicsac.com/russian-churches-sacramento/
PLS help me figure out what’s wrong with that! Thanks!
Hello ruslangr,
First of all, you should remove all your untested plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins. Clear all your caches, purge CDN files and check the results.
