Mobile menu problem
My developer is trying to mirror the site in their app but the code you are using obliges each time to completely reload the page even when the menu is opened, while the current standards (used in the app) no longer use this system.
Can help me to locate this code?
<i class=“tdb-mobile-menu-icon td-icon-mobile”></i>
and replace with this:
<span id=“tdb-mobile-menu-button”><i class=“tdb-mobile-menu-icon td-icon-mobile”></i></span>
I would like to edit this without affecting the hamburger hyperlink and the updating of the theme.
That would be here – http://prntscr.com/n3m8nm you could modify it there if needed. By default there is a link there, changing it to a span may cause it not to work.
Ok thanks! anyway to make it linkable?
If you want it to direct to a link you could change the href on the existing link
– http://prntscr.com/n427rh
This element’s job is to open a menu on mobile when clicked – http://prntscr.com/n424sl A modal should open with the chosen menu.
If this does not work in the app, I would have no idea why it happens. Unfortunately we made no tests in this matter up to this point. Sorry for the inconvenience.
