I use AMP and mobile plugin. There are three options in the settings. USE MOBILE THEME FOR
1) Mobile
2) Mobile + AMP
3) AMP
If I choose the first or second option, the menu is ok. The login option is displayed, the submenu is displayed.
The third option (AMP) makes the mobile menu simpler. No sign-in option. Only the main links are displayed. No submenu is visible.
If I choose the second option, mobiel + AMP, I have to duplicate the page content. When editing the page, just paste the content into the mobile page editor to the bottom. This is very impractical. I use the wpForo plugin on the web. If I paste the shortcode wpForo into a mobile page editor, the forum will appear on the web, but its style is totally scattered.
I need to use option 3) (AMP), but with this option to display the classic, simplified mobile menu, as with option 1). Is this possible?
The problem is that setting (3) (AMP) does not work (
MAIN MENU, FOOTER MENU, SHOW SIGN IN / JOIN. The mobile menu is always displayed as the main menu of the site.
Thank you for your help.
Please try this custom css for mobile arrows, set the code in Theme Panel>Custom code>Custom css and
.td-mobile-content .td-icon-menu-right {
display: block;
For AMP option
-> https://www.screencast.com/t/mZ00jNoM0
If the problem is still there, please provide me a link were I can inspect this problem, in this way I will be able to provide you the right answer.
Also please check this topic about mobile theme plugin and mobile editor -> https://forum.tagdiv.com/topic/the-content-of-the-pages-in-mobile-is-not-visible/
Thank you very much. It works great. But still only the main menu is displayed. The problem is that I have to log in / out in the top above menu. On PC super, no on mobile.
To display the login / logout on a mobile menu, CSS is probably not enough, is it?
Please make sure that you have enable the sing in/ join button from theme panel -> https://www.screencast.com/t/YEvdg0caT0q
Dear,
I know what he means. In the new version 9.7.3 the login / user link does not work anymore in the mobile version. or is no longer displayed.
I tested it and patched every version down to 9.6.1. Without problems. The new version is unfortunately full of bugs in the mobile section of the menu.
Chiao Rick
Dear Calin,
until when can one expect an update?
Have a nice day. Ciao Rick
Dear Calin,
OK. But what solution do you have for the login problem? So now no more users can log in via Responsive and can go to your profile.
many thanks. Ciao Rick
You can downgrade to a previews version where this is working normally, the update to Newspaper 9.7 is all about the envato requirements, you can check the news and fix here section changelog.
If you need a previous version and you do not have it you can send us an email at contact@tagdiv.com and we’ll provide the version you need.
Dear Calin,
OK. I have already done that. But I do not understand about Envato. Did Envato say the theme should be worse and some features should stop working? That does not quite reach me. I’m assuming that an update is always tested before publication. That has nothing to do with Envato. Envato has certainly not said that the login in Responsive should no longer work.
Ciao Rick
