Mobile menu problems and generel header issues
Hello People and TagDiv!
Got a couple of problems which really frustrates me.
First of all. How on earth is it working to create the same header / menu on EVERY page. On my frontpage the hamburger for mobile is white, and the menu shows up when I press it, but when I go to an article or a category pages the hamburger turns in to a different color, and afterwards no menu is showing when pressing it. Also the logo jumps up a little bit on category and post pages.
Last but not least the only place my website is fully loading on mobile is the frontpage. When u visit an article or a category page on mobile you can see how the “loading” bar for the browser stops halfway trough.
Have really tried to figure this out, clicking in and out, but cannot came up with the solution.
– Website is: http://www.techx.dk
Hello !
From what I see at the moment on your desktop website, you are using only 1 header.
If you see more headers you will need to check your Cloud library and see how many headers are available in it. If there are more than 1 I recommend you to remove them.
For the mobile issue please make sure that you have cleared your cache. At the moment we cannot see mobile theme active anywhere on your website. Please let us know if it is active and send us a screenshot of your mobile theme settings.
