I’m not sure I fully understand what is the issue. Can you please provide me a screenshot and more details?
Also, the mobile page has the mobile templates from Cloud Library => https://www.screencast.com/t/YCcZ8rL8
About mobile page template if you made a page template and after that, you delete the mobile page without unassigned it from the page still be linked. To remove the linked mobile page you need to create the new one then select the new mobile page after that you can delete the mobile page.
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates https://www.youtube.com/watch?v=SpGkOnJeNZY
The mobile theme comes with its own templates for page, post, category, 404 etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple).
Mobile responsive version of the theme and the mobile page editor can be edit with tagDiv Composer, the mobile theme plugin not.
here is the resultin the mobile when I deactivate the tagDiv Mobile Theme plugin
https://www.screencast.com/t/hUa6a7BOY
Usually, this can be from some extra plugins, so please does a test using only tagDiv plugins, and if you have a child theme, please use the main theme and clear all cache(also from your browser).
Also, please provide more information about the problems you face.
When you deactivate Mobile Theme plugin, then your responsive mobile version will be on which is similar to the desktop version and all should be alright.
If you want to use a mobile page, then you need to assign it to your homepage. For more information about this mobile version please take a look in this article: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
A full explanation you can find here: https://www.youtube.com/watch?v=SpGkOnJeNZY
Unfortunately, I don’t understand the language in the screenshot, please try to translate it into English.
I just checked your website and it seems working well -> https://www.screencast.com/t/eAdqSfPMU6n7 -> https://www.screencast.com/t/HwhmsSJrBZ -> https://www.screencast.com/t/0XkGmPEvGL
I understand that you managed to solve your problem, right?
Also, the mobile responsive is what you see then that you select the viewport on phone => https://www.screencast.com/t/matV17hH, so some settings may apply for each viewport(where is the border blue), and others are not(where the border is black).
The mobile page has the mobile templates from Cloud Library => https://www.screencast.com/t/YCcZ8rL8
If you want to use the mobile theme plugin, you can disable the mobile theme plugin only on that pages/posts (but you can’t disable it for 404 pages/categories pages, etc) from the Gutenberg editor using the following option => https://www.screencast.com/t/axXRJsWby, if you create a mobile page, please check if is set correctly.
