Mobile page display problem
Hi, i followed this document (https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/) to add mobile page, but when I open this in my mobile its shows me Newspaper default page which is totally different from my mobile home page, any help will be appreciated.
Maybe you have activated the tagdiv mobile theme plugin, so please check and deactivate it.
Also, please provide the link to your website.
I deactivate the tagdiv mobile theme plugin, the problem is solved. I want to know what the mobile theme plugin does. If I turn it off, will it have any impact on the mobile side? I saw the introduction of tagDiv Mobile Theme, which says “The Mobile Theme makes your website lighter and faster on mobile. Together with the AMP plugin, it provides the best solution for your website.”
The Amp is deprecated. If you check the topic, you will see differences in mobile versions. Normally, there should be no impact on the mobile side.
