Hello Dears!
I update mobile page with composer but always have to make clean cache for go on live.
Any suggestion to solve this problem?
I think that this problem is because the cache plugin that you are using is not recognize or is not set to be clear when a cloud template or mobile page was edited with tagdiv Composer.
Hi Calin,
Thanks for your reply, but i do not use any cache plugin.
What’s your next advice?
This reply was modified 5 years by
ozgunminare.
I will but i do not know where can find a link such as you want.
Could you explain the path way of the link?
ozgunminare.
ozgunminare.
Hi ozgunminare, you said in the first reply that you must clear the cache https://i.imgur.com/LMYLYSI.png therefore you have a cache, maybe is not a plugin, but is a cache that maybe do not recognize the mobile page when is saved to clear the cache and you need to do it manually.
To can test this, disable that cache and make a new mobile page, then test it in mobile to see the results.
Also provide a scree with mobile page and a link to that mobile page to check it to.
Let me knw the results!
Hi Calin,
I do not use mobile page already it is mobile theme.
I am new and using your theme at that time.
I hope you will help me and solve this problem. Thanks for your support!
ozgunminare.
Hello !
A link to your website means the link of your website, like http://www.google.com for example. If you can send that to us we can inspect and find a solution for this.
Any advice to not to do clear cache every update on website for seen on mobile?
ozgunminare.
Hello !
Yes, no matter what theme you are using, this is not a theme thing. You have to keep your cache cleared all the time in order to run your website in good condition.
We need to take a look and see what can be done there to see if a fix can be done in order to fit your needs.
– admin url and credentials
Our team will take a look !
Please note that at the moment the Support team is not 24/7 available. We answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2
