Mobile Phone display issue
I have a website which uses the Gossip cloud template.
When I use my pc to view the page https://nextlevelonlinemedia.com/ everything looks good but…
When I view the same link on my phone it shows the word GOSSIP in big letters at the top left corner.
Not sure why that is showing on phone but not pc?
I changed the logo for mobile https://i.imgur.com/xXfs4tY.png -> https://i.imgur.com/Xe1YvR4.png
Also, this is the article on how this can be changed -> https://forum.tagdiv.com/add-logo-newspaper/
Hi Anamaria,
Still a couple other issues with display on devices…
This is as screenshot of a post and you can see proper header logo title
But when I scroll down post the logo changes and says Gossip.
https://www.screencast.com/t/0quM6CsnG
https://www.screencast.com/t/tNQte9tesIiG
I forgot to change for sticky, but anyway you can find all this information in the article above or in this video https://www.youtube.com/watch?v=HXQQygkCCJo
Hi Anamaria,
Thanks for all your help and patience…
2 issues on mobile..
1. If I’m on the home page and click the menu
icon on upper left a box pops up with all the menu categories
and it says to sign in. Also most of the menu links don’t open
up anything. Not sure if that’s because they are mega-menus…
2. If I click on any article link it shows some generic blue
heading that says Next Level Online Media. Not sure how that
go there.
Thank you again.
So, if you want to remove the sign in please go in Theme Panel -> Header -> Sign In/Join and disable -> https://i.imgur.com/bOg0Chf.png
Also, you need to create your menu -> https://forum.tagdiv.com/main-menu/ -> https://forum.tagdiv.com/mega-menu/ they no longer open because those categories no longer exist. These do not work on the desktop version either.
2. I haven’t seen what you mean by ” article link it shows some generic blue
heading that says Next Level Online Media”.
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
Good Morning Anamaria,
I disabled the signin feature in the theme panel but it still
shows the signin when I hit the menu icon in mobile.
Yes, because you have the mobile theme plugin activate.
You need to disable the sign-in/join from Theme Panel -> Mobile Theme -> Header https://i.imgur.com/1XdWker.png
