Mobile problems
Hello
I just discovered that when I open up my Newsmag website in mobile it looks like this:
Mobile view
It looks normal in browser, how do I fix this?
http://www.magasin55.se
Hello Seniordeal,
Now, I have inspected your website and your blocks seem to work as expected, as you can see here -> https://www.screencast.com/t/tk0CNiKM63EU Most likely, your Visual Composer was disabled.
Hello again, when I tried to turn off the JetPack module, then it worked.
Are there any problems with the?
Seniordeal
Hello Seniordeal,
No. As you can see, the Jetpack plugin is very big which has more modules and which can interact with the theme core files and causes a lot of unknown issues. It is best to avoid this problematic plugin (some modules) if you want to bring best theme results.
