I am using “mobile responsive” and it mostly displays properly on mobile devices. However, nothing populates in the posts at all on my iPhone. When viewing from the TagDiv editor in mobile view, the posts are fully there.
Please provide the link to your website and some screenshots from your iPhone.
Thanks Anamaria,
It’s in a dev environment currently. Is there a way to send you the credentials privately to sign in to see the front end?
Screenshot of a post – https://www.screencast.com/t/TBRJf7oN
Link URL – https://777d4d1bc1.nxcli.net
I sent two emails with the requested information. I didn’t include all of the information in the first so I sent a second.
I am having a similar issue. We updated our website with this new theme. It looks great on the desktop but it is not loading properly for mobile nor does it even look the same. I need this to be resolved. Thanks
You may be having the same issue I had earlier. Try deactivating the mobile plugin. I believe this will default to the responsive mobile option which follows the desktop layout.
